Transform effect problem premiere
Sebastian Forssman
on May 22, 2017 at 12:44:33 pm
Hello!
I have a problem with The transform effect.
To start with i worked well. I apllied it to several clips where i wanted to use it.
I unchecked The "use composition shutter angle" and set my own to like 180.
Here is where The zoom transition stopped working. If i check the composition angle marker it starts to work but then i dont have any motion blur.. This problem has accured many times. Its really annoying because i cant find any solution to it.
Dave LaRonde
Re: Transform effect problem premiere
on May 22, 2017 at 3:18:52 pm
Your description sounds like you're working in After Effects. I would render out the shots in question and re-import them into PP.
Dynamic Link isn't exactly fault-free. There are bugs in the process.
Dave LaRonde
Promotion Producer
Sebastian Forssman
on May 22, 2017 at 4:48:11 pm
No, this is actually in Premiere pro Cc 2017.
This problem has been around since i started to use it in premiere pro cs6.
The effects works fine in The beginning of The editing, but after a while i stops working. I then have to shut The motionblur off, then it works again. But hey, we need that motion blur.
Anyone else with this problem?
Dan Powers
on May 22, 2017 at 5:38:56 pm
Well I hope it isnt buggy now that you have pointed out a way to get motion blur on a basic transform! Never used that plugin!
Daniel Waldron
on May 23, 2017 at 8:49:16 pm
Works for me fine in CC 2015. I have used this effect quite often and never had a problem.
Sebastian Forssman
on May 25, 2017 at 6:29:22 pm
Its strange. Because it works well, and then suddenly it stops working if i've set my own shutter speed. if i check the "use composition's shutter angle" it works fin again. But how can i change the composition shutter angle? I cannot not fin anything about compositions in premiere pro, only sequence.
Chris Spellmeyer
on Mar 16, 2018 at 5:18:04 pm
I am having the exact same issue, can't find a workaround! V.12.0.0
Sebastian Forssman
on Mar 16, 2018 at 9:55:43 pm
I found the solution! You have to nest the clip before applying the transform effect!
