applying effects too slow
Mike Tyler
on May 22, 2017 at 8:23:56 am
Hey,
so I am editing some 4k footage, already got it down to 1/8 res, preview file format (in sequence settings) to P2 1080i and made 1080p proxies (which also took ages to encode in Media encoder)..
I've also pre-render the in and out points. I get a fluent playback, but with adding effects (color correction) I have to wait couple of seconds to even see the result of my changes. And immediately as I move a slider, the green bar above the timeline turns to red again. WTF ?
I am editing on a Macbook Pro Retina and usually things are pretty fast..
So I guess I am doing something wrong here ?
Jon Doughtie
Re: applying effects too slow
on May 22, 2017 at 1:20:44 pm
Is your media on separate storage, preferably a RAID array? What is your connection to that storage?
Once you add color correction, every pixel is changed from any pre-rendering you had done.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
