Why does "K" select my tracks?
Anders Haavie
on May 21, 2017 at 9:22:22 pm
One way of editing that I do alot is to put a long footage down on the timeline, start to move around with JKL. I enter an in and out point, and cut the boring part away. (backspace or ripple delete)
When moving around I usually end up pushing "k" at some time, to stop at a certain point in the timeline. This automatically selects the track in the timeline, so I must "deselect all tracks" before removing the part between In and Out point.... so I don't remove the whole track.
I end up having to using the shortcut "deselect all tracks" alot, to make this workflow work.
Is there a brilliant smart idea to make "K" select tracks, that I have missed?
Anders
Xraid-Xserve-Xsan-Xeverything
Anders Haavie
Re: Why does "K" select my tracks? (SOLVED)
on May 23, 2017 at 8:31:23 am
IT WAS A BUG!! (I think)
If I start a new project and import everything into that new project, everything works. If I work with the old project everything is back to the select hell again.
Good to know that Premiere is "not supposed to work this way"
Anders
