GPU upgrade, for CS6 (cant afford cc right now)
ryan johnson
on May 20, 2017 at 3:36:14 am
Hi. I was going to upgrade to the GTX 1070 for my PC (windows 7.0, adobe premiere CS6). I currently have a Quadro 2000. Unfortunately, I dont think that GTX 1070 is compatible with CS6 software, and I don't wish to upgrade the Adobe Suite. Can you recommend a card that is a noticeable upgrade and also compatible with Adobe CS6? The Quadro M2000, maybe?
Dave LaRonde
Re: GPU upgrade, for CS6 (cant afford cc right now)
on May 20, 2017 at 3:56:17 pm
Why would you want to do that? In CS6, GPU is essentially worthless. Furthermore, Adobe can't make up its flippin' mind on the kind of GPU it recommends for current versions. It'll probably change in 6 months.
Now, if you want to get the new card because you absolutely need it for another application, get it for the other application. Don't get it for PP CS6.
Dave LaRonde
Promotion Producer
