Problem with exporting XML from Premiere
Marko Ristić
on May 19, 2017 at 10:26:43 am
Hi!
I have a problem exporting project from Premiere to Final cut. Every time i try to export i get this report :
Sequence at 00:00:00:00, audio track 9: Effect on Clip not translated.
Translation issue:
Sequence at 00:00:34:09, audio track 1: Transition not translated, Cross Fade ( 0db) used instead.
Translation issue:
Sequence at 00:00:36:17, audio track 6: Effect on Clip not translated.
Translation issue:
Sequence at 00:00:42:18, audio track 7: Transition not translated, Cross Fade ( 0db) used instead.
Translation issue:
Sequence at 00:00:46:17, audio track 6: Effect on Clip not translated.
Translation issue:
Sequence at 00:01:46:00, audio track 8: Effect on Clip not translated.
Translation issue:
Sequence at 00:02:15:05, audio track 6: Effect on Clip not translated.
and so on...
So i tried to make a workaround. I rendered all the tracks in wav. and that worked. But the problem is, that is not entirely something that my client wants.
The only ''effect'' expect one Expontial Fade that i had, is basically just animating sound levels on different audio files in the project.
Is it possible that XML cannot translate this very simple effects ? Does somebody has similar experience and is there a solution to this problem?
Also i tried 3 different version of Premiere; CS6 CC2014 and CC2017 the same thing.
Daniel Waldron
Re: Problem with exporting XML from Premiere
on May 19, 2017 at 4:26:07 pm
I would think there are very few effects that translate from Premiere to FCP. Unfortunately it appears Cross Fade is not one of them.
Marko Ristić
on May 19, 2017 at 5:20:17 pm
Even though is just two simple keyframes on sound level ?
Peter Garaway
on May 19, 2017 at 10:56:53 pm
Hi Marko,
Premiere Pro can translate crossfade from FCP but it appears FCP cannot do the same. We had to do work on our end to support many of these effects.
Sorry, this may not be very helpful for you but thought I'd include it. This is a list of the effects and transitions Premiere supports from FCP.
https://helpx.adobe.com/premiere-pro/using/importing-xml-project-files-fina...
Peter Garaway
Adobe
Premiere Pro
