Moving objecs
May Kindred-Boothby
Moving objecs
on May 16, 2017 at 3:32:18 pm
Hello,
Does anyone know of a plug-in to allow more control over the movement of objects in premier?
I'm putting together a frame by frame animation, and i need to be able to edit the sequence of the frames as i go so don't want to use after effects (where it seems you can only import a seqeunce of images, that you cant really then edit them?) but i also want to move it. I've nested them and am using the position and rotation key frames, but i need more control (akin to after effects)
Any suggestions?
