Premiere Playback / Import problem?
Jason Trimble
on May 12, 2017 at 11:17:50 pm
Can anyone tell me why this is happening in Premiere?
The raw footage looks like this:
Playback in premiere looks like this:
Exported ProRes file looks like this:
Shot on a Canon C100.
Mac OS Sierra, AMD Radeon R9 M390 2048 MB
Premiere CC (current update)
Chris Wright
Re: Premiere Playback / Import problem?
on May 13, 2017 at 11:32:44 am
where are you screenshotting the RAW from? or the exported prores? premiere uses 0-255 sRGB. any video player that doesn't match premiere is not using opengl api drivers. also, your gfx card might have settings called 16-236 or 0-255. vlc player can match premiere if you set its renderer to opengl. if you import the media back into premiere, does it change?
Jason Trimble
on May 13, 2017 at 4:35:12 pm
Thanks for your reply and apologies for my unclear statement of the problem. After a couple more hours of research I found that the problem was that Premiere was interpreting the .mts files from the C100 as interlaced. My sequence and previews were set to progressive of course so that resulted in the poor image quality in playback.
The solution was that I had to tell Premiere to interpret the footage as progressive and then everything was good.
Frustrating that Premiere doesn't seem to work well with .mts files.
Thanks again.
Chris Wright
on May 13, 2017 at 5:06:41 pm
thanks for posting the solution. also, keywords 'jaggies', or 'low quality' would have helped. a small pic isn't going to give interlacing away unless its blown up 800%. I only brought up the gamma issue because your screenshots have varying gamma. the window gets blown out. that's not from interlacing.
John Pale
on May 14, 2017 at 12:52:48 am
Did you import the media or use the Media Browser?
Media Browser usually does a better job of figuring out how to deal with different formats.
