Premiere CAN'T handle h264 MOV?
Michele Poggi
on May 8, 2017 at 1:34:13 pm
I had this problem with my old Workstation, and it's the same with a new one.
...So, this has to be a Software Issue.
I have recorder (with OBS) some .mov video files with h264 encoding.
Premiere couldn't import them (it took audio only) without Quicktime installed, and it's ok.
But then, when I import them, it CAN'T handle them.
In no way.
It doesn't do playback at all, you can't work with them. It shows 1-2frames every 3-5 seconds.
It's as like it can't read them properly.
And I don't even know how to explain it more in-depth, it seems quite a simple fact to describe: It's impossibile to work with them...
And I honestly don't know what to do, except encode them with handbrake, since even AME will show infinite amount of hours to handle them.
"Freelance Post-Producer"
Editor Video
Graphic Designer
Digital Compositor
Mail: snm.poggi@gmail.com
Mobile: +39 3349129191
Skype: sabakunomaiku
Dave LaRonde
Re: Premiere CAN'T handle h264 MOV?
on May 8, 2017 at 2:00:05 pm
Quicktime's implementation of h.264 has always ben bad. For now just transcode the footage, and in the future go with mp4/h.264.
Dave LaRonde
Promotion Producer
Michele Poggi
on May 9, 2017 at 8:39:45 am
Indeed...! Thank you very much.
I'm remuxing the files now. OBS actually create horrible desynchs while recording in mp4, so I'll change my workflow.
Daniel Waldron
on May 8, 2017 at 2:02:04 pm
H.264 is more suited for final delivery than for editing, but Premiere can certainly handle it. What are your computer specs?
Jeff Pulera
on May 8, 2017 at 2:09:45 pm
Just helped someone on another forum that was having issues with OBS files in Premiere. By default, the OBS recordings were using VARIABLE Frame Rate, which Premiere doesn't like. Use the free HandBrake app to convert the recording to CONSTANT Frame Rate, then edit the new file in Premiere.
Jeff Pulera
Safe Harbor Computers
Chris Wright
on May 8, 2017 at 3:38:08 pm
I thought I read an adobe post on OBS where he forced recording in constant frame rate without needing to transcode.
Michele Poggi
on May 9, 2017 at 8:41:10 am
I'll check it out!
Though I can't find the option in OBS Studio for now, I'll search throughfully.
Michele Poggi
on May 9, 2017 at 8:40:48 am
They should handle it!
CPU: AMD Ryzen 1700X
MOBO: PRIME X370-PRO
RAM: 2x Corsair Vengeance 16GB 2400MHz
GPU: Nvidia GeForce GTX 1080
Ole Kristiansen
on May 9, 2017 at 10:18:15 am
Try rename the MP4 extension to M4V
