4K Playback - Is my system to weak?
Bernd Hauser
on May 4, 2017 at 1:33:16 am
Hello dear Community
I am having big troubles running 4k files - SPEED UP BY 400% or more - in Premiere Pro CC 2017.
4K Files: .MOV H264 MPEG 4 AVC, 23.976 fps
The sequence settings are matching the files: Editing Mode: DNxHR 4K
No filter or effects.
CUDA or OpenCL makes no difference.
Full, 1/2, 1/4 etc. Playback: no difference
61 GB RAM available for Premiere Pro
Mac Pro (2009)
2 x 3.33 GHz 6-Core Intel Xeon
64 GB DDR3
GeForce 980 4GB
Internal SSD
Same project is running on a Windows 4 Core 3.6 GHz, 32 GB, GeForce 970 without any problems.
Isn't this a very powerful system, and shouldn't the files run smoothly?
Or do i get something wrong?
Thank you very much for your opinion!
Shane Ross
Re: 4K Playback - Is my system to weak?
on May 4, 2017 at 2:27:30 am
What hard drive is this footage stored on? The SSD?
H.264 MPEG-4...isn't DNxHR. Those are two different codecs, so your sequence settings and clip settings don't match. Not that it matters, just saying they are different. H.264 takes a bit to decode on the fly.
Perhaps the driver for the GPU is more up to date on the Windows side?
Shane
Little Frog Post
Tero Ahlfors
on May 4, 2017 at 7:22:41 am
[Bernd Hauser] "Isn't this a very powerful system"
Not really. You should try transcoding the H264 files to DNxHR or Prores.
Edward Laws
on May 4, 2017 at 7:35:26 am
Agree about transcoding to ProRes or DNxHD and making sure your sequence settings match the footage.
Try doing a disk speed test perhaps, Blackmagic have free utility I think.
You might want a RAID0 on two drives or at least have a separate SSD for footage and one for your OS.
Al Bergstein
on May 6, 2017 at 4:43:00 pm
That is a very old machine by today's standards. I have an iMac from 2014 and while it runs 2k footage great, it chokes on 4k. I like the idea of transcoding. That makes sense. I'll try it and see if it helps Probably time for a computer upgrade but I'll start with SSD drives in the Raid bay too.
Al
Bernd Hauser
on May 15, 2017 at 5:51:42 pm
Hey Everyone
Thanks for taking time to answer.
After i took your suggestions into consideration i can report the following:
- Working from SSD. So that shouldn't be the problem
- GPU Drivers are up to date
- Transcoding to ProRes and edit those files works fine. BUT: The files are 10 times the size then the original H264 MPEG. The files come from a DJI Mavic Pro. So the quality is already - lets say borderline, and i dont want to risk even more lost due to compression.
I recently bought this 12 core 3.22 GH because my Macbook Pro (2,8 GHz Quad-Core Intel Core i7 Prozessor) couldn't handle the 4K files.
I understand that the 12 core 3.22 GH is a very old machine by today's standards.
But it should be still a very powerful machine, or not?
I dont understand why a Windows 4 Core 3.6 GHz, 32 GB should bring the performance and a 12 core 3.33 GH doesn't.
Is it possible, that the performance of one core is more important than the sum of all cores multiplied by the performance of each core?
Thanks for your answers
B
Power
Vince Becquiot
on May 20, 2017 at 2:54:45 am
You'd be surprised how quickly CPU and as important, everything around them become obsolete.
Here are some benchmarks to give you an idea: https://browser.primatelabs.com/mac-benchmarks.
You can transcode to a lower quality format to edit and replace at render time.
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
