premiere video flashes constantly after exporting?
adam barefoot
on Apr 3, 2017 at 3:52:28 pm
So i've been having an issue for a month now on different videos on different hard drives. Whenever i have 2 assets overlap (video/graphic/vignette/transition) the video flashes to black and back over and over. I have rendered using both settings under file>preferences>general and the 2 choices given. Below is a video example, sometimes its this bad sometimes its only slightly noticeable on one asset. so anyone know the fix?
example:
Jon Doughtie
Re: premiere video flashes constantly after exporting?
on Apr 4, 2017 at 7:07:46 pm
Adam, there's a LOT more than two render options in the Adobe suite, so I guessing you may not be experienced with it.
We need more information, such as the computer you are using and how it is equipped, the exact version of the software you are using, the format/codec of your original source files, your sequence settings for your project and your render output settings.
See my signature below for an example of the kinds of information that will help us get started helping you.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
