Toggling between sequences in Premiere Pro 2017
Dale Holman Wallace
on Mar 30, 2017 at 1:56:52 pm
Hi all,
To toggle between sequences, I used to use the SHIFT + 3 command. In the latest update of Premiere Pro, this no longer works!
Does anyone know what the correct command is to toggle between sequences. Or even better, does anyone know what the official name is for toggling between sequences so that I can search for it in Keyboard Shortcuts and set my own hot-key?
Dylan
Dave LaRonde
Re: Toggling between sequences in Premiere Pro 2017
on Mar 30, 2017 at 3:05:29 pm
You mean it's too much of a time-waster to click on the tab for the desired timeline?
Wow......
Dave LaRonde
Promotion Producer
Dale Holman Wallace
on Apr 1, 2017 at 10:12:33 am
Yep, I do! I try to use the keyboard wherever possible. Toggling using the keyboard will save you about 20 minutes over the course of a long editing day, rather than reaching for the mouse each time, especially when you're working with multiple selects sequences.
Jim Townley
on Mar 30, 2017 at 10:28:52 pm
Are you using Version 2017.0.2 Release. I know the latest update took care of a lot of the shortcut problems that I had.
I use Shift+3 to access the Timeline when I am in another panel. Once in the timeline panel, Shift+3 will switch from sequence to sequence. It is working for me.
Regards
Jim Townley
Television Production
Chattahoochee Technical College
Marietta, GA
