Need a colour removed
Tom Tremayne
on Mar 25, 2017 at 12:38:23 am
Hello there!
I was wondering if I could grab some colour correction advice.
Here is the image that I'm trying to correct:
As you can see there's a horrible bluish rainbow like colour over her hands that's caused by an artificial light.
Is there a way to remove this or at least make it less noticeable?
I've had a fiddle around in "change colour to" with not much luck.
Thanks in advance for any responses :)
Chris Wright
Re: Need a colour removed
on Mar 25, 2017 at 12:31:25 pm
any good adobe youtube video should explain this in under 60 seconds if you google secondary color correction premiere pro cc.
Lumetri Color's HSL Secondary controls.
Daniel Waldron
on Mar 27, 2017 at 4:16:43 pm
I personally find the secondary color correction with the "obsolete" three-way color corrector to work better, but maybe that's just because I'm used to it...
Tom Tremayne
on Mar 28, 2017 at 9:35:32 pm
It worked!
Less noticeable now.
Thank you for your help ☺
Tom Tremayne
on Mar 28, 2017 at 9:38:03 pm
Here is the corrected version:
