Zoom Audio Changes After Compression
David Powell
on Mar 21, 2017 at 11:26:00 am
I have a strange problem where zoom audio sounds fine on my timeline. When I export it (in any format) it sounds fine on my computer speakers, but if I reimport that file into premiere, the sound goes faint. The same thing happens when you listen to it on a tablet or phone. Never had this happen before. Any ideas?
Simon Ubsdell
Re: Zoom Audio Changes After Compression
on Mar 21, 2017 at 12:19:45 pm
Your audio channels are out of phase. Try using just one of them rather than both, or put them back into phase.
Simon Ubsdell
tokyo productions
hawaiki
Todd Perchert
on Mar 21, 2017 at 6:48:15 pm
I think Audition has a plugin to fix phase issues. Or, depending on what you're doing, I usually just have dialog on the zoom so I convert it to 2 ch mono instead of stereo.
TC
David Powell
on Mar 21, 2017 at 6:56:58 pm
Thanks for the replies. I used the "fill right with left" effect, which I think is doing the trick.
