Cannot edit audio when track volume levels are applied
matt chapman
on Mar 12, 2017 at 10:34:07 pm
Hey all-
Having a real annoying issue with Premiere where I have a track which is the temp score. When i put audio on it everything plays fine, but when I add audio keyframes on the volume level on the TRACK, I can no longer edit the events. I have to create a new track, move it to there, and then re-edit, then copy down the track volume level manually. Very annoying.
Can you not edit a track once you have applied the volume level (and added keyframes)?
thanks
Chapman
matt chapman
Re: Cannot edit audio when track volume levels are applied
on Mar 13, 2017 at 5:48:59 pm
UGH, this is really annoying. Happens all the time, is there a setting that can be changed?
jerry wise
on Mar 13, 2017 at 7:38:17 pm
Make a "blade cut" while holding the "shift" key.
jerry wise
on Mar 13, 2017 at 7:55:06 pm
i see what you mean now. i made audio clip keyframes and then made track keyframes and got the same result you did. as long as i am in the Track Keyframe mode then the audio channel can't be highlighted unless i click off Track Keyframes and go back to Clip Keyframes.
matt chapman
on Mar 19, 2017 at 9:24:25 pm
Does anyone know if this is an option that can be turned off?
Irritating that if i include an audio track and even make a base mix keyframe on it to bring it down I then cannot edit anymore from there on the audio track.
Eric Santiago
on Nov 8, 2017 at 8:10:23 pm
A colleague of mine applied keyframes under track keyframes.
He then wants to move the group including the audio clip to a diff point in time.
He can do this but the track keyframes don't follow.
Not sure how he got to this point I avoid using audio keyframing in most NLE.
I use ProTools for things like that.
