Add multiple titles to every clip?
quang huy
on Mar 11, 2017 at 1:48:51 am
Hi everybody!
I want to add titles to every clip on my timeline. How can i add multiple titles to the beginning of each clip with the same attributes (durarion, font size, title effects...)?
Thanks for reading!
Vince Becquiot
Re: Add multiple titles to every clip?
on Mar 11, 2017 at 1:55:33 am
Hi Quang,
Once you have a first title, use the "New Title > based on current" feature to create additional ones.
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
Quang Huy
on Mar 12, 2017 at 1:07:46 am
Thank you Vince!
Can you guide to me to make new titles automatically fit the clips? I created new titles but have to pull it to fit the clips manually.
Quang Huy
on Mar 13, 2017 at 6:12:44 am
Please help!!!
Alex Udell
on Mar 13, 2017 at 1:51:52 pm
Hi Quang...
I assume this is based ont he project we just worked thru the blurs on....
if so, i assume you have many many titles to create
One thing to understand that is that titles are clips of their own in PPro...and not effects added clips.
because of this...there is not a real "batch" way of handling this in PPro.
so you have to consider yoru workflow overall to deal with this in an painless a matter as possible.
I'd suggest that the title tool probably isn't the most effective here, as you will have to create all the titles manually...
So there are a couple of options...
Photoshop: There are ways of creating batches of files starting with data in an Excel spreadsheet.
This can be good, if you need to generate a lot of titles quickly ( as it seems you do)...and if you decide later that you need to go back and adjust the styling.
Here's a sample of that workflow:
Another avenue might be to approach this using After Effects.
There is a script for After Effects called "Comps from Spreadhseets"
here you could make batches of titles and then bring them into PPro as Dynamic linked comps. meaning you can change them later as well.
Here results can also be animated by designing the animation as part of the base composition.
Here's info on this:
http://aescripts.com/compsfromspreadsheet/
Neither of these will automate the process of placing them into your PPro editing sequence.
It's up to you to get the edits into the timeline.
but once there..it would be easy to updated and change.
hope that helps...
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Quang Huy
on Mar 13, 2017 at 2:38:02 pm
Hi Alex!
I'm so glad to see your comment. I'm new here and there are so many to learn, i'm grateful that you guided me devotedly.
Thank you for spending your time with me. You're a kind gentleman!!!
Sorry for my bad english btw...
Alex Udell
on Mar 13, 2017 at 5:21:51 pm
Glad to try and help.
Alex Udell
