Low quality still image renders. What are we doing wrong?...
Dave Draper
on Mar 9, 2017 at 8:32:10 pm
We have a video with still image overlays on it (company logos, etc), but every time we export out of Premiere -- using the GoPro Cineform YUV 10-bit codec -- the images in the video appear low in quality with fuzzy edges (like a smaller image that has been upscaled), when in reality, they are higher in resolution than the source video.
If we export using either the GoPro CineForm RGB 12-bit with alpha or Maximum Bit Depth variation, the images in the video appear high in quality, with crisp edges -- as they should -- but all video transitions in the edit are ignored.
Clearly we're doing something wrong somewhere, but does anyone know where?
David Roth Weiss
Re: Low quality still image renders. What are we doing wrong?...
on Mar 9, 2017 at 9:33:58 pm
Post a screen shot of your sequence settings please.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Dave Draper
on Mar 9, 2017 at 9:46:01 pm
David Roth Weiss
on Mar 10, 2017 at 2:40:37 pm
Change your sequence settings... First change Editing Mode to DNXHD, then change Preview File Fornat to one if the DNX options. The defaults, i.e. DSLR and MPEG I-frame are shredding your still image quality.
David Roth Weiss
Los Angeles
Dave Draper
on Mar 11, 2017 at 7:49:26 pm
David. Many thanks for your suggestion. Unfortunately, this hasn't made a difference to the image quality...
andy patterson
on Mar 10, 2017 at 12:25:45 am
What happens if you render using the CPU instead of the GPU?
Jeff Pulera
on Mar 10, 2017 at 2:28:52 pm
Hi Dave,
You said the overlay graphics are higher resolution than the video, which means Premiere has to be doing some scaling. Take that out of the equation. In Photoshop, make the graphics all 1920x1080. Bet that helps. Even if just a corner bug, put it in a 1920x1080 frame with transparency.
Jeff Pulera
Safe Harbor Computers
Dave Draper
on Mar 11, 2017 at 7:56:21 pm
Tried this as well, but hasn't made a difference.
I swear I encountered this problem a few years back, but managed to solve it somehow. Just can't remember how. Very frustrating.
All I know is, the only way I can (currently) get the video to look the way it should look, is by exporting at 12 bit with the alpha channel.
Dave Draper
on Mar 11, 2017 at 7:49:46 pm
Still the same...
Korin Unka
on Mar 14, 2017 at 7:45:45 am
Maybe delete your "common" folder under appdata>adobe ... could be caching issue
Dave Draper
on Mar 14, 2017 at 3:58:28 pm
Deleted the cache, and hasn't made any difference, unfortunately...
Dave Draper
on Mar 14, 2017 at 4:34:47 pm
Interestingly, if I create a new title (so not an image, but New Item -> Title...), the same problems occur.
Korin Unka
on Mar 14, 2017 at 7:31:41 pm
What bit depth do you have your imported image and also the project. Wonder if your mixing the project ir sequence settings. Might also be a bug based on it working for different formats but not that setting. Could be worth posting it to adobe
Dave Draper
on Mar 15, 2017 at 5:07:26 pm
All images are 8 bit...
I'll see if anyone on the Adobe forums can shed any light.
andy patterson
on Mar 14, 2017 at 7:39:56 pm
It should not be that hard to correct. It may be a bug. Are you on Mac or PC?
andy patterson
on Mar 15, 2017 at 1:00:50 am
Did it used to work? Could it be an update issue?
Dave Draper
on Mar 15, 2017 at 5:10:29 pm
I remember that this has happened before -- but this was years ago now -- and I'm pretty sure it was all resolved by clicking a checkbox somewhere, or changing some setting. I just cannot, for the life of me, remember anymore than that.
Dave Draper
on Mar 15, 2017 at 5:08:01 pm
I'm on a PC. I've tried both the 2015 and 2017 versions of Premiere Pro. Same deal.
Dave Draper
on Mar 20, 2017 at 4:44:29 pm
Can anyone think of any other suggestions?
Ole Kristiansen
on Mar 20, 2017 at 6:21:45 pm
Export settings, are you using: Optimize Stills ?
In the Video tab in Advanced Settings !
