Timeline lost
Sébastien St-Martin
Timeline lost
on Feb 27, 2017 at 8:12:06 pm
Hi guys,
Here's the problem: when I open a project in Adobe Premiere CC 2017 (mac) everything seems fine until the project is open and can't find the timeline/source monitor, workspaces, etc...
When I hit the space buttom as a play buttom, I can hear the sound of the sequence like if the timeline is somewhere outside the display. I usualy use two screen but even if I disconnect one, it doesn't work.
Here's what I tried :
Window/source monitor... and all that stuff
Window/workspaces (all the preset I had and all pannels)
File/new sequence
Open another project/new project
Delete and reinstall premiere
Reset premiere preference
Systeme preference/display, arrangement, position, scale, etc...
In the adobe window menu, I can only open the timecode window...
My adobe premiere 2015 is working fine.
Thanks a lot for your help!
Phillip Brock
Re: Timeline lost
on Feb 28, 2017 at 2:19:45 pm
have you tried double clicking on a sequence?
Sébastien St-Martin
Re: Timeline lost
on Feb 28, 2017 at 8:11:42 pm
Sure!
Sébastien St-Martin
Re: Timeline lost
on Mar 1, 2017 at 4:54:45 pm
Here was the solution :
Go to : /Users/NAME/Library/Application Support/Adobe
Then change the name of the folder Common by Common1 and Premiere Pro by Premiere Pro1
Then relaunch...
Thanks to the Adobe Premiere Support !
