Premiere Pro 2017.0.1 Laggy "Play" playback - GTX 1080, SSD Raid, Xeon E5-2630 2.20 GHz (2 processors)
Sander Somma
on Feb 27, 2017 at 2:14:31 pm
Greetings! No response at offical adobe forums.
System info:
GTX 1080
SSD 0 Raid (hardware)
128 GB Ram
Problem:
Adobe Premiere is lagging, freezing when using "Play" button. Fine when scrolling timeline.
File type: MXF, 2k.
Also strangely, when this lagg occurs, task manager reports 100% CPU usage. Also after the start up "play" lag, it countinues fine, at 2% CPU usage.
I could not find anything on this matter, a few older threads around the web with no answers. Can anyone help me out please?
Thank you!
Gary Huff
Re: Premiere Pro 2017.0.1 Laggy "Play" playback - GTX 1080, SSD Raid, Xeon E5-2630 2.20 GHz (2 processors)
on Feb 27, 2017 at 2:45:07 pm
[Sander Somma] "Adobe Premiere is lagging, freezing when using "Play" button. Fine when scrolling timeline. File type: MXF, 2k."
What codec are you recording to?
Sander Somma
on Feb 27, 2017 at 3:02:25 pm
Hey! Recording? Im not recording to any codec yet. Playing back the material when editing is laggy and freezes. CPU jumps to 100% for a second, have not had any similiar trouble. I read somewhere it might be about raid doing double checking or something, but does not make sense because its freezing and laggy because CPU jumps to 100% for a moment. Seems like an software issue, but if that would be the case then this wouldnt be such unusal problem.
Joy Kawk
on Feb 27, 2017 at 3:10:28 pm
what's the codec of your video and what's your sequence setting ? I'm not sure but laggy playback happened when they were different as far as my expericne concered....
Sander Somma
on Feb 27, 2017 at 3:17:31 pm
Hey!
Thanks for replying guys!
I tried "New sequence from clip" and different sequence settings, did not change anything.
Sequence settings:
1920x1080
Square pixel
25fps
Editing mode: arri cinema
Compsite in linear color
Material properties:
File Size: 21,23 GB
Image Size: 2048 x 1080
Frame Rate: 25,00
Source Audio Format: 48000 Hz - 24 bit - 4 channels
Project Audio Format: 48000 Hz - 32 bit floating point - 4 channels
Total Duration: 00:14:20:16
Pixel Aspect Ratio: 1,0
MXF File details:
Wrapper type: MXF OP1a (type: SingleItem SinglePackage MultiTrack Stream Internal)
File generated by: CANON, EOS C300 Mark II (1.00)
AVC Intra 444
Joy Kawk
on Feb 27, 2017 at 3:22:17 pm
Ah, you are working on MXF files too?(Me too) Are you editing MXF in CC or CS vertion? 'Cos I found that the playback of MXF is more smooth in CS6 than in CC. (just my onw opinion....)
Sander Somma
on Feb 27, 2017 at 3:25:31 pm
Hey! Yes,
Premiere Pro CC 2017.0.1
Dave LaRonde
on Feb 27, 2017 at 4:19:37 pm
This sounds like it was originally imported into Avid. I'd just import the original clip.
Dave LaRonde
Promotion Producer
Sander Somma
on Feb 27, 2017 at 4:26:44 pm
Hey!
These are straight copied to SSD raid, original clips.
Chris Wright
on Feb 27, 2017 at 5:06:26 pm
do they work if you change preview to 1/4 resolution?
Sander Somma
on Feb 27, 2017 at 5:08:26 pm
No, the preview does not change anything. Scrolling on timeline is fine tough, like I mentioned.
Chris Wright
on Feb 27, 2017 at 6:01:22 pm
hmmm. are you mac? 10.12.3 MacOs fixed some premiere issues
here's some more ideas:
Choppy playback in Premiere Pro
https://forums.creativecow.net/thread/3/974536#975716
Sander Somma
on Feb 27, 2017 at 6:02:14 pm
Hey! Im on PC
Ann Bens
on Feb 28, 2017 at 12:25:41 am
Have you considered updating to 2017.0.2?
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
andy patterson
on Feb 28, 2017 at 4:56:43 am
Did it used to work and now it does not? Could it be the Nvidia display card drivers?
Sander Somma
on Feb 28, 2017 at 11:00:22 pm
I will be checking if I can update to newer version. It did work before. Im not sure how and when this happened. I uninstalled and reinstalled, nothing. Today I uninstalled again and also used Adobe Cleaning tool but wont install before I get newer version. Still tough it should never use 100% to freezing Premiere with such powerful CPU.
Other formats, full hd wont even play perfectly.
Sander Somma
on Mar 1, 2017 at 6:48:59 pm
Greetings. Clean install, of new version 2017 1.02. It got better by 15%. There has to me some massive bug or failure somewhere.
Chris Borjis
on Mar 2, 2017 at 1:30:38 am
Is it set for OpenCL or CUDA acceleration?
I would switch to OpenCL if it is currently CUDA or vice versa (something to try)
I had awful lag with 1080p AVC multicam with CUDA but switching to OpenCL solved it.
There was some buggy cuda stuff going on recently.
If that does nothing try disabling mercury transmit if it is enabled.
That might help too.
Nice system by the way!
