Viewing all clips in a sequence from the bin
doug brown
on Feb 24, 2017 at 8:54:44 pm
Is there a way to view all the clips that are within a sequence but from the bin(s) where they live in the project (ie. clip info metadata etc.)? I believe this was "decompose sequence" or some such thing in Avid once upon a time.
doug brown
editor-dougitorial LLC
jerry wise
Re: Viewing all clips in a sequence from the bin
on Feb 25, 2017 at 5:27:22 pm
well what i do is to make a "bin unused" in the project pane. then go to "edit" "remove unused" then hit undo and all the unused clips will be highlighted. then drag the highlighted clips to "bin unused". now you have a bin used and a bid unused.
doug brown
on Feb 27, 2017 at 10:24:45 pm
That worked great. Thanks.
doug brown
dougitorial LLC
