Subtitles/Captions workflow
Glix Martín
on Feb 22, 2017 at 6:25:33 am
I am working in the subtitles of a short film but I haven't found a lot of information about how to organized the work using Premiere Pro CC.
Is there any info about how to do it? The project is not a very complicated one but I was wondering what program I should use. It seems that other people use other tools but Premiere but it seem to me that Premiere might be enough for me.
But if I use Premiere, should I create a "Caption Clip" (I don't know how to call it, "A caption item"?) for the whole project starting pretty much at the beginning of the time line all the way to the end or I should group all the subtitles, for examples by sequence, each sequence with its own caption item?
And Is there any way to save the parameters from one block of captions to other? It seems that, for I don't know what reason, when I add a new block/page of text, the setting might change, the location of the text has change, the size, the color for the edge is different.... is there a way to lock all of that?
