How to record voice over in mono?
Joel Arvidsson
on Feb 21, 2017 at 8:19:24 pm
I want to record voice over in premiere in mono. Im recording with a mono mic but Its gets recorded as a stereo track with only voice in one channel? Where do you change this? Seams like even if i set a mono track, the voice over will record in stereo plus one empty channel. Where should i do the changes? Is it in premieres channelmixer or perhaps i have looked in the wrong end.
//Joel
Jo Liesendahl
Re: How to record voice over in mono?
on Feb 21, 2017 at 8:25:13 pm
Hi Joel,
make a new audio track in your timeline, set it to mono.
Add the record-symbol to your audiotrack-icons, activate record on that mono track.
Best,
Jo
Jon Doughtie
on Feb 21, 2017 at 8:26:20 pm
Unless you go back and reset your timeline to have mono tracks, it might be simpler to simply make the mono track play as stereo.
In the Project/Bin panel, select your mono clip. Choose Clip > Modify > Audio Channels. In the Modify Clip dialog box, select Mono As Stereo, and then click OK. Note: You can apply the Modify Clip command to a mono clip only in the Project panel, before the clip appears in a Timeline panel. If you have already placed it in the timeline, you'll need to place it again.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Dave LaRonde
on Feb 21, 2017 at 8:31:14 pm
OR.....
Record it in Audition. It'll do mono. And it's easy to use.
If, when done recording, it takes more than a minute for a well-organized individual to get the recording into PP, something is definitely amiss.
Dave LaRonde
Promotion Producer
