Importing complicated FCPX XML's into Premiere -- Possible?
Aryn Leigh
on Feb 16, 2017 at 1:11:24 am
Hi there-
I'm working on a large-scale project where I need to import into premiere several older sequences that were cut in FCPX. So far, I'm exporting FCPXML's into DaVinci Resolve and then back out to a Premiere-readable XML file. (I am side-stepping XtoCC here.)
Unfortunately. Many of the provided FCPX-edited timelines were done using a multicam feature, so the sequences come in as unreadable nested files.
Is there a workaround to this, besides working directly in FCP?
This is a unique situation- not a typical workflow scenario, but one we are forced to work with. Many thanks in advance!
Nicholas Lear
Re: Importing complicated FCPX XML's into Premiere -- Possible?
on Feb 26, 2018 at 6:11:31 pm
I also ran into this problem today, with FCP XML's from a multicam sequence not behaving after import into Resolve.
Haven't found a lot about this on the web.
John Pale
on Feb 28, 2018 at 2:55:55 am
X to CC claims to work with FCPX multicam clips but does collapse them to regular clips with the active angle only. That’s better than an unusable nest. Its not horrifically expensive.
