XAVC 4K Editing
Michael Harrington
XAVC 4K Editing
on Feb 15, 2017 at 9:17:41 pm
I'll be using the Sony FS5 for the first time to shoot 4K and my understanding is I'll need to select XAVC codec.
I'll be editing in Adobe Premiere Pro CC2017 on my MacBook Pro Retina, 15inch, mid 2015, 2.5 GHz Intel Core i7, 16GB Ram with AMD Radeon R9 M370X 2048 MB Intel Iris Pro 1536 MB graphics card.
Aside from the obvious, I won't see 4K on this monitor, how will the performance be on this laptop editing Premiere Pro CC2017 XAVC codec?
When I take delivery of camera I won't have much time for testing before I need to start shooting so any one with experience shooting with the Sony FS5 4K and editing with Adobe Premiere Pro CC2017 on a MacBook Pro would be much appreciated.
Michael Harrington
MacBook Pro (Retina, 15-inch, Mid 2015)
16 GB 1600 MHz DDR3
Apple Cine Display 30"
Thunderbolt 2 Dock
GTech GSafe, GTech Drives
Adobe CC2015
Premiere Pro 9.0.2
David Roth Weiss
Re: XAVC 4K Editing
on Feb 15, 2017 at 10:08:04 pm
Before you shoot anything get at least one clip somewhere to test, because XAVC is not an easy codec to edit. It's possible Adobe has optimized Premiere to better support it, but for a long time that was not the case and it was a real bear. You'll know almost instantly if your computer can handle it, just change the opacity and/or reposition two layers of the same clip - if you drop frames at 1/4 resolution you'll know immediately that you'll need to transcode it to ProRes.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Peter Garaway
Re: XAVC 4K Editing
on Feb 15, 2017 at 10:51:23 pm
Hi Michael,
As David mentioned, XAVC is not kind on your CPU. I have your same laptop as you, I'll see if I can locate a few clips to test with. If you have a sample file you'd like to share, I can try those as well.
Do you know the FPS your assets will be? 4k60p is something Premiere is struggling with. We're working on improving this.
Best,
Peter Garaway
Adobe
Premiere Pro
Michael Harrington
Re: XAVC 4K Editing
on Feb 16, 2017 at 12:05:55 pm
I couldn't of asked for more qualified answers, thank you.
Yes, I'll test, I'm concerned I won't have time for a thorough test. This project is single camera short-form while future projects are long-form whereas I shoot multi-cam motorsports events resulting in 60-75 hours footage to be edited in to 5 15-minute segments. I agree with Davids quick test procedure, should I expect PPro on this laptop to bog down depending on amount of footage, length of timeline, layers of videos, etc?
Peter, let me know what you discover. I've searched the web and so far can not find a XVAC file to test with. I'll shoot either XAVC QFHD (3840 x 2160) @29.97p or 23.98p 100Mbps/60Mbps. Can you tell me which frame rate plays nice with Pro.
I'm also considering a workflow that includes shooting HD 1920x1080 and XVAC 4K editing both in PPro project HD 1929x1080. Shooting XVAC 4K for interviews and product shots to save production time and enable editor to punch in or create moves with motion and key framing.
Any thoughts?
Michael Harrington
16 GB 1600 MHz DDR3
Thunderbolt 2 Dock
Adobe CC2017
Peter Garaway
Re: XAVC 4K Editing
on Feb 17, 2017 at 5:33:50 pm
Hi Michael,
I don't expect you to have any issues with 29.97p and 23.97p footage. Of course this is dependent on how many layers you have and the type of effects used. In general you should be fine though. As David mentioned, XAVC is not the most friendly editing format. If you get into a case where performance is not what you need, you can always go into a proxy workflow using Cineform or ProRes.
If you haven't seen the proxy workflow check it out here:
https://helpx.adobe.com/premiere-pro/how-to/proxy-media.html
There's lots of other tutorials online you can find as well.
If you need any help along the way, feel free to reach out.
Peter Garaway
Adobe
Premiere Pro
