Nesting in premier
Nathan Kendall
Nesting in premier
on Feb 10, 2017 at 7:27:06 pm
I set a clip to nest and applied warp stabilize. I got a message stating warp stabilizer needs dimensions to solve nest footage......
I added warp stabilizer to the nested timeline. I keep deleting and creating new nesting. this time it nested footage and shows in green in original sequence but not the new sequence that is suppose to be nested.
11038_nested.png.zip
Jon Doughtie
Re: Nesting in premier
on Feb 10, 2017 at 7:51:07 pm
Warp Stabilizer can be a peculiar animal. I will usually isolate the shots I want to stabilize, render the individual shots to see if I like the result, then export to a non-lossy codec so the effect is "baked in". I'll import those "baked-in" shots to my project and work with them in the edit.
Warp Stabilize is pretty much the only time I do this routine. Just simpler in the long run for me.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
