Export subtitles as time-coded transcript?
Elizabeth Johnson
on Feb 7, 2017 at 11:09:54 pm
Hi all,
I'm working on a film that requires a lot of translation. Instead of creating a timecoded translated transcript, I did much of the translation as subtitles within a Final Cut Pro 7 project file. Is there a way I can export these subtitles as a text document with timecodes? Some third party software I can use?
I could also bring the whole project into Premiere and try to export it that way. Does anyone have suggestions? It would be too time-consuming and complicated to copy and paste them all, and too much work has been done on hundreds of hours of footage.
Thanks for any advice!
Simon Ubsdell
Re: Export subtitles as time-coded transcript?
on Feb 8, 2017 at 5:08:02 pm
Check out Title Exchange Pro from Spherico:
http://www.spherico.com/filmtools/
It does an incredible variety of things and should be ideal for your FCP 7 project.
Don't take it into Premiere as this will make the process a lot more tricky.
Simon Ubsdell
tokyo productions
hawaiki
Elizabeth Johnson
on Feb 9, 2017 at 7:59:13 pm
Thank you, Simon! Have you used it yourself? Were you able to make an actual time-coded transcript and did you have to do any modifications to it?
Life is worth living.
Simon Ubsdell
on Feb 9, 2017 at 9:01:44 pm
I've used it in numerous different ways and on pretty much every subtitle job we ever do.
The simplest method for you purposes it is take an XML out of FCP 7 and turn it into a Text file that you can then edit, and turn back into whatever type of subtitle file you choose.
But that's just the simplest option - there are countless possibilities, depending on your needs.
I can't recommend it enough.
Simon Ubsdell
tokyo productions
hawaiki
Elizabeth Johnson
on Feb 10, 2017 at 7:09:58 pm
Thank you, that's really helpful!!
