autosave in premier
isa alshabany
autosave in premier
on Feb 7, 2017 at 6:09:22 pm
Hello ..
greetings to all ..
how can i make premiere cs6 autosave over right the fixed number of times set .. i have set it at 20 times every 7 minutes .. but once it reached 20 times , it doesn't over right the old ones & start over again ??
thank you very much
isa
Joe Barta IV
Re: autosave in premier
on Feb 8, 2017 at 2:17:49 pm
Does it stop Autosaving or does it just add more files?
Joe
Living the SuiteLife!
Stuff for editors http://www.cafepress.com/suitelife
http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
isa alshabany
on Feb 15, 2017 at 8:53:48 am
Hi Jeff
thanks a lot .
the problem is The " AUTO SAVE " doesn't over right the old ones ??
thanks
Jeff Pulera
on Feb 8, 2017 at 3:32:35 pm
Hi Isa,
The 7 minutes/20 copies setting will do this:
It will Auto-Save a copy every 7 minutes, with 20 unique copies being saved. This should cover 140 minutes of work, after which the oldest auto-saved copy then gets overwritten with newest save and so on. There will never be more than 20 copies saved at once, and "oldest" copy would not be more than 140 minutes old during any work session (unless you exit Premiere then of course they stop updating).
Jeff Pulera
Safe Harbor Computers
isa alshabany
on Feb 15, 2017 at 4:50:02 pm
Hello Joe
it stop AUTO SAVING .
thanks
isa
