How do make a specific part of the video zoom?
Harris Majeed
on Feb 5, 2017 at 4:03:18 am
Hello everyone, i am in need of help with Premiere. I recently made the switch from Vegas Pro to Premiere and i'm getting the grips of it but there's one thing that i don't know how to do.
I want to make it so that a specific object in the video zooms in but the scale of the video itself is normal, only the object, is this possible in Premiere Pro?
Thanks.
Dave LaRonde
Re: How do make a specific part of the video zoom?
on Feb 5, 2017 at 8:54:08 pm
Now, this piece of video you want to shrink o nothingness -- do you want to leave an object-shaped hole behind, od do you want it to shrink over the object? It makes a difference.
Dave LaRonde
Promotion Producer
Harris Majeed
on Feb 6, 2017 at 3:26:08 am
https://gyazo.com/5b4a800ea9b1c3470ecf176f909f281f
Example
Duke Sweden
on Feb 6, 2017 at 1:14:12 pm
You need to have your "shrinking object" as a separate track. It has to be keyed out so that only the object appears, then you can shrink it or grow it to your heart's content.
Dave LaRonde
on Feb 6, 2017 at 3:50:56 pm
That looks like it was done in After Effects. Placing a cloud layer as the background, it's text over a masked solid with horizontal feathering, then text & solid are parented to a null object. Scale the null from 100 to 0.
It's a job that takes... oh, less than 5 minutes.
Dave LaRonde
Promotion Producer
Harris Majeed
on Feb 6, 2017 at 3:57:37 pm
Nope. It was done in Premiere. Even he said it himself.
Harris Majeed
on Feb 7, 2017 at 1:37:37 am
It looks like i found the solution. You have to duplicate the video and place it on the track above the normal video.
Then, mask the opacity on the second video and scale it bigger/smaller and tada.
