Color shift when exporting through Media Encoder
Timothée Ferreol
on Feb 4, 2017 at 6:12:32 am
If I render from Premiere the color looks as I color graded them but whenever I queue it to Adobe Media Encoder, there is an horrible color cast, do you know a way to fix that please ? I suppose it is a color space problem, but have no idea how to fix it
Premiere : (OK)
Adobe Media Encoder (not OK):
___________________________________________
If you want to check out my work =) : https://vimeo.com/timof
Timothée Ferreol
Re: Color shift when exporting through Media Encoder
on Feb 4, 2017 at 6:25:24 am
Okay I found out the solution :
"Copy the LUTs from PP app "package" Contents/Lumetri/LUT/Technical Folder, and paste everything to AME Contents/Lumetri/LUT/Technical Folder."
worked out :)
Jeff Johnson
on Oct 4, 2018 at 7:18:50 pm
Thank you so much! This was very very helpful.
