Is there a way to limit processor use during rendering?
Steve Adams
on Feb 1, 2017 at 7:22:50 pm
When Premier Pro is rendering it brings my computer to its knees so I can't do any other work. Is there a way to tell it only use, say, 30% of the processor? I don't mind if it takes all day, but I'd like to use the computer during the day.
Or maybe a way to pause the rendering.
Jon Doughtie
Re: Is there a way to limit processor use during rendering?
on Feb 2, 2017 at 8:56:46 pm
Without a lot more information about your computer, storage, and what file type you are working from and rendering to, we can't really say.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Steve Adams
on Feb 3, 2017 at 2:58:56 pm
Ok, thanks. I thought a "PAUSE" might at least be available. I knows Windows has ways to suspend threads, and it doesn't seem that hard for Adobe to connect a PAUSE button to one of them. But I guess not.
Thanks.
Steve Adams
on Feb 4, 2017 at 1:06:35 am
I've discovered another data point on this issue. If I just hit Return after a bunch of edits and let PP render the timeline, the load on my system isn't bad. Task Manager still says all 4 CPUs are running are 100% but I'm able to do other work and barely notice that there's a heavy task also running on the machine. When the load is intrusive is when I ask PP to build and export an mp4 from the timeline.
I'm guessing that the build/export entails a lot of disk activity and that's the hold up, while the render just spins around inside of memory.
Steve
