How can I achieve this simple transition effect on a title?
Ashley Davis
on Jan 30, 2017 at 10:17:33 pm
Can anyone suggest how I might be able to achieve this simple transition for a title? I can do it in AE but will take a while, is there a quick effect in Premiere to allow you to achieve this look?
Dave LaRonde
Re: How can I achieve this simple transition effect on a title?
on Jan 30, 2017 at 10:20:51 pm
Are you referring to the subtitles at the head, or something else in that 38-minute-long file? If it's elsewhere, a time would be helpful to have.
Dave LaRonde
Promotion Producer
Ashley Davis
on Jan 30, 2017 at 10:24:41 pm
Sorry! I did c&p with the time code but must have not work.. an example is at 7:53
Duke Sweden
on Jan 30, 2017 at 10:34:29 pm
That looks like a built in text animation preset in After Effects. I believe you can open that folder in Bridge and look at how each animation works before applying.
Dave LaRonde
on Jan 30, 2017 at 11:20:20 pm
Duke's on the right track. It looks like text animation in AE.
You could start with a preset, perhaps a couple, and then modify them.
Once you get a look at all the presets, you may find something you like even more.
Dave LaRonde
Promotion Producer
Duke Sweden
on Jan 31, 2017 at 3:13:48 am
Lookit me on the right track over here ;-)
Dave LaRonde
on Jan 31, 2017 at 4:06:08 am
Well, I do dead-simple cutting in PP. Absolutely nothing tough. For everything else I run to AE. I've doing it that way since Media 100 version 4. So I know AE a lot better than PP.
Old habits die hard.
Dave LaRonde
Promotion Producer
Tero Ahlfors
on Jan 31, 2017 at 8:10:03 am
https://helpx.adobe.com/after-effects/using/animating-text.html#animate_tex...
Ashley Davis
on Jan 31, 2017 at 11:54:48 am
Thanks everyone so much! Had no idea that Bridge allowed effects previews like this! This has saved me so much time! ☺ ☺
