Accurate audio re-speeding in Audition / Premiere Pro
Matthew Heeley
on Jan 23, 2017 at 5:54:15 pm
Hello Creative Cow Crew!
Long time fan - first time posting. ☺
I need to do a lot of re-speeding of audio where we have foreign language overdubs for TV shows that have come from a 23.98fps source and I need to re-speed the audio files to sync them up with a 25fps video source.
Our previous workflow used Sample Manager to do this, and it mostly worked very well. But now we need to use Premiere Pro or Audition instead. The re-speeding will obviously be the same % increase every time - so I'm really just looking for a robust and reliable approach using Premiere or Audition to do this.
Can anyone recommend a simple / tried and tested method for performing good quality re-speeding of this type?
I have tried using the rate tool in the Premiere Pro timeline but that seems to give me crappy results that sound out of phase.
Any advice is greatly appreciated!
Cheers
Matt
Jon Doughtie
Re: Accurate audio re-speeding in Audition / Premiere Pro
on Jan 23, 2017 at 9:21:57 pm
Yeah, the timeline rate change gets that flange sound to it.
You'll want to do this in Audition. Clean as a whistle if you do it there.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
