Efficient way to produce a J-cut
Yair Bartal
on Jan 1, 2017 at 7:17:19 pm
As can be seen in the following clip:
https://www.dropbox.com/s/72adss2uc1p22k5/test1.mp4?dl=0
The 1st time I Alt(to select video only)+drag to trim, it succeeds.
The 2nd time it causes the video and audio to get out of sync.
This is with Ppro CC 2014.1 and 2015.4.
I don't have yet 2017.01.
Can anyone confirm this behavior also occurs with 2017.01?
jerry wise
Re: Efficient way to produce a J-cut
on Jan 2, 2017 at 4:40:38 pm
i think it will work if you tic "shift clips etc.." in Prefs/Trim
Yair Bartal
on Jan 2, 2017 at 5:08:57 pm
Good catch Jerry, that worked.
In fact that option was apparently introduced with CC 2015.
Thanks.
