I can't drag in a full sequence
Christian Szokolay
on Jan 1, 2017 at 10:57:37 am
So basically every time I have "sequence 1" where some video and audio clips are synced and cut and I import it into "sequence 2" Premiere will only bring in a section of "sequence 1" into "sequence 2". I then have to drag "sequence 1" several times to the end of the timeline so I can see the entire "sequence 1" within "sequence 2". Is there some setting Premiere has that tells it to only import a section of a sequence? It feels like I have invisible in and out points set by defautl or something. Any help will be greatly appreciated.
Thank you,
Chris
EDIT: So I have found that manually setting in and out points within a sequence accomplishes what I'm trying to do but it's still weird that by default Premiere won't import the entire sequence.
John Pale
Re: I can't drag in a full sequence
on Jan 1, 2017 at 6:07:48 pm
Use the Media Browser to open the sequence in the Source Monitor, then select all, cut/paste into the destination sequence
Duke Sweden
on Jan 1, 2017 at 8:06:20 pm
I did have that happen to me as well right after I upgraded to cc 2017 but, like all the other quirks, it suddenly stopped.
