Automatically move images
Job van den Berg
on Dec 30, 2016 at 1:21:18 pm
Hello,
Im creating a complilation video with loads of images in it. To make the images less "static" I want to make them move a little. I know I can do this manually by adjusting the position and key frames but I wonder if there is an effect which will do this automatically for me. Any ideas?
Kind regards
Jon Doughtie
Re: Automatically move images
on Dec 30, 2016 at 3:06:41 pm
I usually manually make three or four moves and save them as presets. Then drag and drop to taste.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Dave LaRonde
on Dec 30, 2016 at 3:49:13 pm
Apparently it doesn't bother you that you'll see the edges of the clips if you move them around in the frame... unless there's something you haven't divulged.
Dave LaRonde
Promotion Producer
jerry wise
on Dec 30, 2016 at 5:04:25 pm
You could use "Jarle's Deadpool Handheld Camera Presets" found on the Cow somewhere as a download as i remember.
Ann Bens
on Jan 1, 2017 at 11:44:01 am
https://www.proloststore.com/products/burns
Or make loads of presets in Pr.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
