Change keyframe range in timeline
Alfredo Canziani
on Dec 28, 2016 at 12:28:32 am
I'm trying to ease out a scaling effect. So, I thought that using the keyframe in the timeline could have been a reasonable idea for editing the Bezier handles.
Here you can see the opacity chart, of the grey clip, is set to 100% as it is the scale effect of the central clip, on the far right hand side. Unfortunately it is squashed to the bottom of the window, and makes it unusable.
I would like to make it look like this, but without having the initial scale set to 10,000.
Is there a way to change the range (y-axis) of the keyframe chart in the timeline area?
Thank you.
Alfredo Canziani
Re: Change keyframe range in timeline
on Dec 29, 2016 at 4:49:07 pm
OK, I've figured it out. One has to use the Effect Control panel. The Timeline Keyframe view is pointless and misleading.
Here there is a view of my panel, where I can control both the x and y range.
