Stuttering Playback on CS4 Source Monitor
Robert Gilbert
on Dec 27, 2016 at 1:53:36 pm
Greetings. Could anyone please counsel me on a possible solution (or workaround if necessary) to the stuttering playback of my Pro Res 422 HQ footage on the SOURCE monitor?
SD footage played well but not this HD which played well on the timeline after rendering but never on the Source monitor.
These are my specs:
2048 x 1080 in ProRes 422HQ on CS4 on OSX Lion:
Model Identifier: iMac11,3
Processor Name: Intel Core i5
Processor Speed: 2.8 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 4 GB
Processor Interconnect Speed: 4.8 GT/s
Boot ROM Version: IM112.0057.B00
SMC Version (system): 1.59f2
Serial Number (system): W80257T5DB5
Hardware UUID: C7156188-35C1-5CC6-AF55-8E3C75CB2EF1
Thank you very much!
David Roth Weiss
Re: Stuttering Playback on CS4 Source Monitor
on Dec 27, 2016 at 4:41:44 pm
You need to tell us what you're using for a media drive. If it's just a single spinning disk it's not giving you the throughput you need for ProRes HQ. You'll either need a RAID, with 2-drives striped together, or you'll need to step down to a lower bitrate ProRes version such as 522 or LT.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Chris Wright
on Dec 27, 2016 at 4:48:47 pm
to add to this, you can do offline edits then replace master media folder when ready to export full HQ, like a manual proxy.
Robert Gilbert
on Dec 27, 2016 at 5:31:56 pm
Thanks, Chris.
Robert Gilbert
on Dec 27, 2016 at 5:27:31 pm
Thank you very much, David. Wish i had known that before i converted R3D to HQ. I would have gone with LT.
Now, i've already started editing everything directly on the timeline: a slow workflow, but it seems like my only choice at this point.
