4k file playback Premiere & Windows
Bill George
on Dec 17, 2016 at 2:16:10 pm
I have a Asus laptop running spec -
Intel i7 2.4Ghz, 16GB RAM, graphics - NVIDIA geforce GTX970m
I have a desktop PC spec -
AMD FX 4170 QUAD CORE 4.2GHZ processor - 32 GB RAM - geforce nvidia GTX 770
I cannot play or edit 4K files on either , the footage sticks ,
I have researched so much , played around with the VLC player and NVIDIA control panel , - I've ticked the GPU acceleration in the control panel etc...
The laptop I am espiecially surprised in the laptop not playing back as 4k playback is marketed as one of its benefits the desktop I could imagine that I would have to upgrade the processor to watch - but I thought at least I could get up and running with this setup -
The CPU is 98% maxed out when I try to play back ,
Can anyone advise me what I am doing wrong , with regards to Premiere should I download a new codec
What is best to shoot for easier playback - PRORES or DNX format?
So yes after alot of research I am really struggling for a solution ..
Chris Wright
Re: 4k file playback Premiere & Windows
on Dec 17, 2016 at 7:55:22 pm
if you have 4k, you would need a brand new 6 core new i-7 @4.2GHZ
The easiest transcode/preview codec on your cpu is cineform. if that doesn't work, your cpu just can't handle online editing.
You can still use the offline proxy mode in premiere which is also automatic now.
https://helpx.adobe.com/premiere-pro/using/proxy-workflow.html
some premiere tweaks you could try
https://forums.adobe.com/thread/2234109
Bill George
on Dec 18, 2016 at 9:11:03 pm
thanks chris
I am looking at i7 intel processors now - would an earlier one do like this ?
https://ark.intel.com/products/47932/Intel-Core-i7-980X-Processor-Extreme-E...
good price second hand
Dave LaRonde
on Dec 17, 2016 at 9:12:50 pm
Consider this: every frame of 4K footage contains 4 times as many pixels as HD footage. 4 times as many bits as before. 4 times the computation. Why then would you be surprised that you're having problems editing on a machine that could barely keep up with HD?
Wake up.
Dave LaRonde
Promotion Producer
Vasco daNeva
on Dec 21, 2016 at 9:34:50 am
I have a 6 year old Toshiba Qosmio, 8 gig RAM. Just finished a 45 minute 4K film without trouble. Yours might be a compatibility issue. My specs are much lower than what you have and I work just fine.
Bill George
on Dec 22, 2016 at 12:26:59 am
yes Vasco - this is for sure a configuration problem not about power ,
can i ask you what media player you use to watch 4K files on your laptop , and what codec settings you use within it ?
this is drving me nuts ,
Vasco daNeva
on Dec 22, 2016 at 2:11:51 pm
I have the free VLC player but I have no idea what codec(s) it uses. Must be something from the K-lite pack because that's all I ever installed. However, my laptop screen is not 4K, so I am not really watching UHD.
Bill George
on Dec 22, 2016 at 12:34:02 am
OK so I upgraded today
i7 Intel 4.2ghz 32gb ram GTX 770 nvidia graphics , (will upgrade to a power card soon )
Still VLC and 5k player will not play back the 4k files ,
so this is a configuration and codec problem , I've spent hours looking into this ,
Do you use a stand alone player to watch 4k files ? if so which one and what codec settings ?
This has really thrown me I have to say
Bill George
on Dec 22, 2016 at 1:13:34 am
the gtx 770 does not display 4k only through the display port ......
Tero Ahlfors
on Dec 22, 2016 at 6:59:10 am
What is the format/codec of the 4K footage you're trying to play? Not all 4K is created equal.
Ole Kristiansen
on Dec 22, 2016 at 8:38:28 am
GTX 770 GPU specs
3840x2160 at 30Hz or 4096x2160 at 24Hz supported over HDMI.
4096x2160 (including 3840x2160) at 60Hz supported over Displayport.
Support for 4k tiled MST displays requires 326.19 driver or later.
Sunderland Green
on Apr 20, 2017 at 10:31:25 am
Which version of Premiere Pro CC are you using, if you are using Premiere Pro CC 2015 version or above, you can create proxy files with small resolution directly with it.
greg janza
on May 3, 2017 at 6:37:26 pm
As Tero suggests, you need to know what type of 4k material you're trying to play back. What's the codec and data rate?
The ability to play back 4k is primarily a function of the speed of your thru put. What type of drive is the media on? How fast are those drives. You can use the Blackmagic speed test utility to quickly determine if your drives are fast enough.
Also, the best place to test out your footage is inside of Premiere since you can choose your resolution level. I would avoid VLC.
Here's an Apple White paper on pro res data rates to give you a sense of the bandwidth you'll need to play back pro res 4k:
https://images.apple.com/final-cut-pro/docs/Apple_ProRes_White_Paper.pdf
