Can my Macbook handle 4k footage?
Roberto Cavagnero
on Dec 15, 2016 at 8:25:49 pm
Hello, I have a mid-2014 15" Macbook Pro with 2,2 Ghz i7 Cpu, 16 Gb of ram and Intel Iris Pro and I found that Premiere Pro struggles to play 4k footage from Sony Fs5 (MXF files) and after a while it begins to seriously "stutter". Do I have any chance of fixing this? Do I have to work with proxies?
Will Duncan
Re: Can my Macbook handle 4k footage?
on Dec 15, 2016 at 9:22:51 pm
Without a dedicated video card, it's going to be tough. CPU and RAM meet minimum requirements, but the onboard Iris card will be a major bottleneck. Native MXF from the camera would probably benefit from converting to something else to reduce the load, but that's a band-aid on a bigger wound I'm afraid.
Complexity of your timeline will always be an issue as well.
I haven't personally worked with external GPU's as of yet. But I do know people working with RED footage who offload that heavy lifting to an external box.
The good news, we can always work smarter. Hardware shouldn't be a limitation unless you're working for time / speed on deadline. Premiere is so much better at handling Proxy workflows now, the only major downside is taking the time to convert everything, which I personally welcome in the age of how fast can we produce stuff. Gives me time to organize and put things away properly.
Chris Wright
on Dec 16, 2016 at 2:17:47 am
im going to throw this out there since it doesn't cost anything to tweak premiere, except your time.
tweaking premiere to playback smoother:
https://forums.adobe.com/thread/2234109
Joy Kawk
on Feb 27, 2017 at 6:32:16 am
Actually I remember Premiere pro has proxy or what for lager video file(either in file size or frame size).But I haven.t tried it myself. Maybe you can try it.
