Can you copy captions data from one captions file to another in Premiere?
Sara Wasserman
on Dec 13, 2016 at 8:06:10 pm
I've created a captions file to export to a .srt sidecar file in 1920x1080. The video was shot in 6K so I'm working on another export in that higher resolution. So I have to create 2 separate caption files because of the different sizes. Is there a way to copy/paste the caption data (similar to markers) into the new 6K captions file? Is there a workaround where I can continue with the same 1920x1080 captions file? Thanks ☺
Sara
Icaro Lobo
Re: Can you copy captions data from one captions file to another in Premiere?
on Dec 14, 2016 at 1:25:53 am
Select your caption file on Project window.
File > Export > Captions > XML Format
Reimport the XML into your 6k project.
Sara Wasserman
on Dec 14, 2016 at 3:11:49 pm
Thank you! It just worked for me. I'm guessing that the size you select when you create the file doesn't matter using this method because it looks great in VLC. 😸
