Importing video with alpha channel issue
sam bowman
on Dec 13, 2016 at 10:19:59 am
I have a video that is meant as a transition. basically a hole is to open up spinning on the screen getting bigger to display the video underneath it. The problem is that the parts of the transition video that are supposed to be opaque have this weird transparency issue. It is like there is a static white noise layer of transparency over the entire clip. You can see it best in the black in the corners. I will include pictures
it is supposed to look like this (picture taken from sony vegas which works properly for this clip) where the black is solid
I'm really at a loss here, I am on a windows 7 machine running Adobe Premiere Pro CC 2017. Here is the metadata for the clip in question.
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2005.03 (qt )
File size : 1.54 GiB
Duration : 10 s 0 ms
Overall bit rate mode : Variable
Overall bit rate : 1 323 Mb/s
Encoded date : UTC 2016-12-22 12:07:05
Tagged date : UTC 2016-12-12 12:21:04
Writing library : Apple QuickTime
©TIM : 00:00:00:00
©TSC : 25
©TSZ : 1
Video
Format : RLE
Format/Info : Run-length encoding
Codec ID : rle
Bit rate mode : Variable
Bit rate : 1 321 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : RGBA
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 25.475
Stream size : 1.54 GiB (100%)
Language : English
Tagged date : UTC 2016-12-22 12:07:05
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 1.83 MiB (0%)
Language : English
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 00:00:00:00
Time code, striped : Yes
Language : English
Any help would be greatly appreciated, I've been stuck on this problem for hours I cant find a solution on my own.
Andrew Drachman
Re: Importing video with alpha channel issue
on Dec 13, 2016 at 2:32:49 pm
Have you tried going in to the effect controls on the clip and changing the opacity to screen?
sam bowman
on Dec 13, 2016 at 10:28:44 pm
Yes, I have tried that it makes the clip even more transparent and you can see more of the video underneath it.
sam bowman
on Dec 13, 2016 at 10:30:37 pm
This is what happens with screen opacity when there is a green matte behind it.
