3d camera tracker to stabilize shots
Dave Rogers
on Dec 11, 2016 at 11:35:48 am
When a shot has been 3d camera tracked and the camera created, is it possible to use the 3d camera to stabilize the shot ?
I am hoping it would give more control than the warp stabilizer.
Thanks for any help.
Duke Sweden
Re: 3d camera tracker to stabilize shots
on Dec 11, 2016 at 12:20:07 pm
You know it's weird, I had the exact same thought last night (and NO, fellas, I don't spend all my waking hours thinking about this!)
I think camera tracking pinpoints a part of the image that you can attach an effect to so that it moves in the same direction, but I don't think you can use it to stabilize an image the way you can in After Effects. If I remember the Video CoPilot tutorial, the image spins and moves around and you need to do a lot of cropping, which will be no problem if you're shooting 4K.
Dave Rogers
on Dec 13, 2016 at 8:47:01 am
Thanks for the reply Duke, the cropping would depend on the amount of stabilization applied but it by that you just smooth the vertical motion for example.
there must be away to smooth movement using the 3d camera tracker I just cant figure out how
