VR Video export flat
Michael Goldberg
on Dec 8, 2016 at 4:55:10 pm
I have a timeline of equirectangular video cut together. The new controls to view the timeline are excellent.
Here's the question though......
I want to export the video flat so someone can view it for ref. not in 360. Is there a way to do that easily?
I basically want to export what I'm seeing when I set the program monitor to VR mode.
Another option would be to export just the front camera? Anyway to do that?
Mike
Dave LaRonde
Re: VR Video export flat
on Dec 8, 2016 at 5:04:54 pm
Do you have a video capture card?
Dave LaRonde
Promotion Producer
Michael Goldberg
on Dec 8, 2016 at 5:25:17 pm
Hi Dave,
No Video Capture Card.
Mike
Peter Garaway
on Dec 15, 2016 at 5:38:47 am
Hi Michael,
While there's not really a designed workflow here you may be able to get the results you want or at least closer by doing the following.
1. Import your VR media
2. Create a custom sequence that is smaller (much smaller) than the actual size of your source video
3. Place the VR clip into the sequence. Be sure to keep the current sequence settings if prompted.
4. Use the Motion controls in the effects panel to scale and position your clip so that it gives you the perspective you want. You can even use keyframes.
5. Export video
This allows you to do a kind pan and scan workflow. Again, this is not a great solution and the quality may be questionable but you can play around with the settings and may get a decent look.
Hope this helps a bit!
Best,
Peter
Peter Garaway
Adobe
Premiere Pro
Michael Goldberg
on Dec 27, 2016 at 10:32:17 pm
Thanks Peter,
Yep, that's kind of what I ended up doing.
Mike
