Multi channel Audio issue
Rojapathi devarala
on Dec 8, 2016 at 8:11:45 am
Hi All
I am using Premier pro CS6 and i am exporting multi channel Audio tracks with PAN as MXF file format and i am importing to check the audio its showing as one track empty.
my export is
track 1 is dialogue PAN is -100
track 2 is dialogue PAN is -100
track 3 is Music PAN is +100
Track 4 is Music PAN is +100
Track 5 is empty
Track 6 is Empty
Track 7 is Mixed
Track is mixed
if i imported this MXF file its not coming as it is .. its -100 & -100 is becoming one track and 2nd track showing empty ...
how will i get the PAN and tracks as it is??
Please help .. TIA
Tero Ahlfors
Re: Multi channel Audio issue
on Dec 8, 2016 at 10:25:56 am
Your sequence needs to be set up as multichannel.
http://blogs.adobe.com/VideoRoad/2015/02/multichannel-audio-in-premiere-pro...
Rojapathi devarala
on Dec 8, 2016 at 12:04:57 pm
Hi Thank you
After import is done with the mxf file .. i am dragging in to my timeline and its asking for the Option for Sequence setting and timeline setting.. i am selecting the sequence setting ...
My Issues is i want to import my audio file as it is with panes and tracks should be the same...
Tero Ahlfors
on Dec 8, 2016 at 12:26:00 pm
Drag the file on the new item-icon below the project panel. You should get a sequence that matches the file.
