keyboard short cut bug in latest version? all command are gone?
Michael Paul
on Dec 2, 2016 at 2:10:22 pm
So I've decided to update to the latest version of Premiere for OSX (because there was a problem that sadly didn't get fixed with the latest build). I've noticed the all new keyboard short cut window BUT I also noticed that it's empty. It doesn't list any command at all. If I search for something like "zoom" it won't display anything either. Is this a common and known bug? Any idea how to set up my keyboard short cuts now? Maybe I can edit a text file like the After Effects short cuts?
Dave LaRonde
Re: keyboard short cut bug in latest version? all command are gone?
on Dec 2, 2016 at 3:59:38 pm
Are you saying you can't use CC 2015? That you have no other choice than to use CC 2017?
If that's so, you're kind of caught between a rock and a hard place. CC 2017 broke a lot of things that previously worked just fine.
Dave LaRonde
Promotion Producer
