Raspberry Pi 3 as External monitoring in Premiere CC
Mat Chevitz
on Dec 1, 2016 at 10:45:30 pm
Hi folks,
Is there a way to configure Premiere CC to send video through Ethernet to a Raspberry Pi3 (connected to a TV via HDMI), and then use the TV as a preview monitor ?
Vince Becquiot
Re: Raspberry Pi 3 as External monitoring in Premiere CC
on Dec 2, 2016 at 12:35:47 am
Hi Mat,
Premiere will recognize any video output device that your computer sees at output device. That usually means any graphics card output.
If the device doesn't show up in Premiere preferences under playback, then you probably won't be able to use it.
What's the purpose of the Raspberry Pi3 in your setup, why not run the HDMI from your machine straight to a TV?
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
Chris Wright
on Dec 2, 2016 at 1:31:11 am
i know ipad can do this called duet display. pi3 as a passthrough, not sure. haven't done it.
here's a promising thread
http://raspberrypi.stackexchange.com/questions/9205/creating-an-hdmi-pass-t...
