Export from PP not good enough
Brett Clancy
on Nov 30, 2016 at 1:50:18 am
After tips about exporting some GoPro footage, that was editing on PP. Sequence setting were AVCHD 1080P - 59.94fps, square pixels, 1920-1080. The exported sequence is not as sharp as timeline sequence. I exported using highest match source -high bit rate, but doesn't look as good as it could. I'm think I perhaps should have selected a better sequence setting rather than let PP decide when you drag your first edit into timeline ..?
Vince Becquiot
Re: Export from PP not good enough
on Nov 30, 2016 at 3:31:50 am
Hi Brett,
Uncheck every single match source box and create your own settings. Start with 20Mbps/CBR progressive. How does it look?
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
Brett Clancy
on Nov 30, 2016 at 4:27:38 am
Thanks for those tips. I think it does look better. I was also curious about exporting FPS - normally I export 25fps by default, but as this vision was shot in 59.95, I wondered if I should export it as that rate or bump it up to 60, for no other reason than 60 seems a firmer number. LOL my enduring lack of tech knowledge.
Joe Barta IV
on Dec 2, 2016 at 3:11:19 pm
If it was shot at 59.95 then export as 59.95,
you gain no advantage by making it 60fps.
Joe
Living the SuiteLife!
Stuff for editors http://www.cafepress.com/suitelife
http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
