Batch edit text layer in image files
Jef Harris
on Nov 29, 2016 at 5:57:05 pm
Does anyone know of any way to batch edit the text layers in a still image?
Little background.
I have 500+ scenes that need scene number labels.
Right now I have to go into each still image and manually edit the scene number.
If I have 500+ still images with the text label "showname_shownumber_scenenumber", (cartoon_101_005).
So "cartoon_101_005" becomes "cartoon_101_006" then" cartoon_101_007" then "cartoon_101_008" and so on.
Iv'e tried looking for a script or a plugin that would do this with no luck.
Hopes are high that there is a faster way to batch edit multiple text in still images.
Jef Harris
Re: Batch edit text layer in image files
on Nov 29, 2016 at 6:49:38 pm
I've also been searching for a plugin that would take the scene file name and use that in a text layer.
Or an "effect" that reads the clip name?
Alan Lloyd
on Nov 29, 2016 at 6:51:05 pm
I think I would look at going about it differently.
I'd do a batch file rename first, according to the conventions you describe. (XNView will do this and it's free.)
Then I'd look at exporting them with the filename supered.
Worth a look, anyway.
Jef Harris
on Nov 29, 2016 at 7:07:12 pm
Sorry, I think I've done a poor job of explaining.
All the files living on my drive are the proper names. That's good to go.
What I want to do is batch edit the Text Layer in the Still Image.
Or have the Text Layer inside the Still Image use the a source file name.
Does this make sense?
Alan Lloyd
on Nov 29, 2016 at 8:21:41 pm
Yes. XNView will do this in the Batch Processing tool. You can define what text you want in the file, including filenames, numbering, etc.
I don't think keeping it in its own layer is an option, though you could set up a subdirectory for the files with supered names.
Grab yourself a copy and experiment. The program is free. (Amazing that it can do all the things it does and costs nothing.)
Jef Harris
on Nov 30, 2016 at 4:13:40 pm
XNView can't edit the text inside a premiere file.
Alan Lloyd
on Nov 30, 2016 at 9:46:52 pm
Which means there was some measure of miscommunication upthread.
Can't help you with that.
