Save Premiere project to open in earlier version
Julius Miller
on Nov 27, 2016 at 10:05:26 am
Hi there
I think I know the answer but is it possible to save a Premiere project so that it is compatible with an earlier version?
I updated to 2017 and now want to revert back to 2015. I have done a couple of projects in 2017 and now want to be able to open them in the 2015 version of PP.
If you can't save the project as an earlier version can you import a sequence? I tried and it did not work but not sure if there is a work around?
Or am I just out of luck?
Jo Liesendahl
Re: Save Premiere project to open in earlier version
on Nov 27, 2016 at 10:18:15 am
Hi Julius,
make an xml export of your timeline and import it into a 2015-project.
Jo
