Premiere Pro : Can't find "Open Caption"
Youne Youne
on Nov 21, 2016 at 11:08:58 am
Hi community,
I'm working on Premiere Pro CC v9.3 and I would like to add some subtitles.
But when I try to insert an open captions, I can't find it in the list. (see screnshot). There is only CEA-608, CEA-708 and Teletext.
Am'I missing something please ?
Thank you in advance.
Katie Gates
Re: Premiere Pro : Can't find "Open Caption"
on Nov 21, 2016 at 5:09:46 pm
I believe that feature is new in Premier Pro 2015 (10.3)
Peter Garaway
on Nov 23, 2016 at 12:26:48 am
Hi Youne,
Katie is right. Open Captions are not available in 9.3.
Here are a few links to how to use Open Captions in 2015 and newer
- https://helpx.adobe.com/premiere-pro/using/working-with-captions.html
- https://helpx.adobe.com/premiere-pro/how-to/subtitles.html
Peter Garaway
Adobe
Premiere Pro
Jeff Coleman
on Jan 4, 2017 at 4:12:45 pm
Hey Peter!
Do you have a link/tutorial on how to do Open Captions in Premiere Pro 15.4? The links sent above don't tell how to add captions or extend the captions clip in 2015.4 (like in 2017).
Peter Garaway
on Jan 4, 2017 at 7:46:55 pm
Hi Jeff,
1. To create an Open Caption go File > New Captions or select the + button in the Project Panel > Captions
2. The New Captions dialog box appears displaying the video settings. Premiere Pro matches the caption video settings to the open sequence. Accept the default video settings and click OK. In the next dialog, under 'Standard' select Open Captions from the drop down menu. Your Caption file will be added to the Project panel.
3. From the Project panel, double-click on the caption file to open the Captions panel.
4. From the Captions panel, you can extend the duration of the Caption file(s) by modifying the out point. Hover over the hot text and drag to the right.
Let me know if that was the info you were looking for Jeff.
Happy New Year!
Peter Garaway
Adobe
Premiere Pro
Jeff Coleman
on Jan 5, 2017 at 1:46:08 am
That works! Thanks Peter!
clarissa qiao wee loi
on May 29, 2017 at 4:15:25 am
Hi what should I do if the option for select 'open caption' don't even exist like what have on the snapshot above.
Jeff Coleman
on May 29, 2017 at 3:28:48 pm
You are using Premiere Pro?
You are using version 15.3 or later?
You are following the instructions from Peter's links above and you do not see the options for "Open Caption"?
If "yes" to all the above, then you may have some unusual problem like a corrupt software installation or something.
If "no" to any of the above then you may wish to provide us more detail about your
operating system,
software version and
project details.
greg janza
on May 29, 2017 at 3:37:01 pm
Another option is to do your open captions outside of premiere. I suggest that because the captioning in Premiere is clunky and has limited options.
Amara.org is a great free resource to create closed and open captions. You can make them on the site and then export a .srt file and import that file into a program like Submerge and marry the captions to your video.
Adobe Premiere 2017.1.1
Windows 10 Pro
Samsung SSD 850 EVO system
Samsung SSD 850 EVO Adobe cache
NVIDIA GeForce GTX 970
OWC Thunderbay 12t x 2 in Raid10 configuration (thru Storage Spaces and Disk Management)
on May 29, 2017 at 10:58:13 pm
I did follow the step given above again and restart my device. Now it's alright. Thanks a lot.
