Best Workflow for Alexa 2K (ProRes 444) with Adobe Premier Pro 2015.3
Rachel Pearl
on Nov 18, 2016 at 9:01:38 pm
I'm cutting a feature using Alexa ProRes 444 footage and Premier. What is the best workflow for this arrangement?
I have a mid-2012 MacBook Pro 2.6 with 8 GB Ram running Yosemite.
Is it reasonable to cut natively or should I use a proxy workflow. We will be syncing and merging clips to cut with so they would have to be matched back laster if we use the proxy path.
I have a faster imac that we could use but it's running Sierra but I've been advised to stick with Yosemite for now.
Rachel
John Pale
Re: Best Workflow for Alexa 2K (ProRes 444) with Adobe Premier Pro 2015.3
on Nov 19, 2016 at 7:42:08 pm
Definitely proxy workflow, it's the whole reason why it exists.
Tero Ahlfors
on Nov 20, 2016 at 10:43:23 am
If you have fast enough storage to use the original files there's no need to use proxies. Prores isn't that intensive codec.
John Pale
on Nov 20, 2016 at 3:05:32 pm
She has a fairly slow Mac Book Pro with only 8GB of RAM. Might be fine for a small project, but performance will not be good on a feature film. I'm using a MacPro 2013 and performance can be sluggish with ProRes 4444. I'm not even sure if that model MBP has a qualified GPU for Mercury Engine acceleration. Sounds like a textbook case for using proxies to me.
